Electronic problem that Porsche canīt fix for me drives me crazy
3rd Gear
Hello,
New member here. Peter from Stockholm Sweden.
First of all my appologies for poor english. I will also try to make long story short.
A few months ago my wife was driving the car, all of a sudden a warning appears "Engine temperature to high". So she parked the car and we had a towtruck taking it to an authorised, and the largest Porsche workshop here in Stockholm.
Ok, so they change the oil level sensor. I got the car back a few days later. Then, after driving apprx 45 minutes the same warning appears "Engine temperature to high".
Ok, so back to the workshop, had the car there for about two weeks since they had to order next piece from Germany. This time they changed the whole instrument cluster, and guaranteed that my problem should be fixed by now.
A few days after i got my car back, the following happens - A new warning: "Oil level monitoring failure. Workshop"
+ The oil temperature gauge, not sure if this is the correct name, (iīm meaning the one that shows oil temperature) start dipping to the bottom (lowest) and then up to its original possition (about middle), and then dip again.
This happens sometimes every 15 minutes, sometimes every other day.
Does not matter if engine is hot or cold.
I have payed around US 2500 (+ the insurance company have payed around US 1000) to Porsche for the repairs, but still they have not solved my problem.
I have been fighting a lot for this. They simply say that electronic issues can be difficult, and i simply have to live with the costs. They claim that they just follow a manual. Finally, after going rather high in the Porsche organisation i managed to get around US 1500 back from them.
They said that the next step for them (again following some manual) would be to exchange the whole "cablesystem" (sorry donīt know what this is called in english).
But since i got some money back from them, we are done with eachother + i donīt have much confident in their workshop, obviously i will turn elsewere.
I have been recommended another workshop that is supposed to be very good.
Let me just hope that they can help me out.
What are your thoughts about this matter that is driving me crazy?
thanks guys
Peter
thanks guys
Peter
A friend of mine just experienced a complete electronic "meltdown" on his GTS this week. PCNA did not seem to what to do other than to throw parts at it. Dealer says it is the third one with the same symptoms in one month.
I think these vehicles are a bit over electronified.
Super Moderator
Needs More Cowbell
Needs More Cowbell
In order to replace it, they will likely remove everything from the interior (seats, carpet, roof liners, door panels, dashboard...basically strip it down to the bare unibody), remove the old wiring harness and install a new (built to order based on the vehicle VIN and options) wiring harness and put the car back together again.
There have been a few pictures of what the insides looks like when it is stripped clean. If not covered under warranty, it would be a very expensive procedure.
The whole "cable system" is the vehicle wiring harness.
Hello,
thanks guys
Peter
thanks guys
Peter
