mObridge and ipod playlists question
I finally got around to creating playlists on the Ipod I keep in the Pepper. Tonight I tried to use one of the playlists and I couldn't figure out how to select/play a playlist. I select CD 1 to get into the playlist menu and can view the 4 playlists but I couldn't get it to actually play a playlist. What's the secret?
Yes, I read the %$#& manual, several times, clear as mud.
Scroll down to the playlist you want to listen to. Press and hold the >> button that's to the right of the 0 button on the keypad. Hold down for 2 seconds. The playlist list tag will change to [>>] and you will enter the playlist. Release the >> button. The playlist will start in about a second. Press and hold for two seconds the << button on the left of the 0 to go back to the main playlist menu.
Hope that helps.
Hope that helps.
For the record, in my manual it says the >> for 2 secs. is to FFWD, which to me is Fast Forward, it makes no mention of anything close to "playing" the playlist.
Hi there's also a menu under CD 6, where you can change the way the buttons respond so you don't have to push the buttons for 2 sec. if I remember correctly.
Hi Cpa4S
A little off topic but Prussian blue is a deep almost violet blue metallic. Depending on the light/angle, it would look dark grey or blue or violet. So it accentuated the curves really well with a hint of different color. Really pretty and would like a car in that color again someday.
