Popping Noise
Popping Noise
Noticed that when car is cold when coming to a stop I hear a pop, more like an air gun sound coming from the front passenger side. Seeing as it is an intermittent problem and it does not make the sound at the dealer I figured I'd ask if anyone had a similar problem?
I was thinking a releas from the air suspension or something?
The only time I've ever heard that is when I had a car load of heavy guys (fishing trip) and we all got out at the same time at a diner for breakfast. The car made a similar noise. In this case, the engine was off. This has only happened once.
Sure it was the car making noise?
The air tube for the air suspension is located at the passenger airbox. It may have come off of the airbox. I hear the noise all the time with the Evoms intake kit, so the frequency is normal. But the fact you can hear it indicates that something is leaking because I never heard it when I had the stock airboxes.
