That is a negative. Only time there is an issue is when I switch out summers to winters and it takes a few trips for the system to sync with the newly installed rims.
I get this all the time in the 911, never in the pig.
I'm wondering about tire rotation. Is it needed? I've had bad luck in doing this on other vehicles, so when I had the pig in for it's first service I told them to skip it.
I called service. They confirmed that there are in fact batteries in the units However...they are not serviceable. I think beru is the maker and probably the same as MB.
I had that - it would show flats every once and a while. They did the harness replacement TSB, then the control box, then the sensors in all of the wheels and that did it. All was under CPO warranty.
