TPM Question
I want to use my Winter wheel / tire set (non-TPM) on my newer 2006 CS Titanium with TPM option. Any problems with this?
I heard it will set off an alert or an alarm. Anything I can do (other than getteing TPM installed wheels) to use them (I don't care if TPM not working since I check them often)?
TIA!
TIA!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
You reset under the menu to the size of tires you are using. Then you have to wait a few trips before the sensors start receiving the information from the rims which shows up on the dash. Until it starts reading you get a warning indicator on the dash.
