Coolant pipes A-Z.
#586
I bought the kit from ECSTuning.com and it had everything I needed - all the gaskets, etc. Suncoast Porsche sells a kit with genuine Porsche parts. When I started to replace my coolant pipes, I discovered that it already had the plastic pipes replaced with the aluminum parts, My leak was at a large rubber connector hose. I still have the pipes and would be glad to sell them. You would have to buy the rest of the pieces. If you are interested, send me a message.
#587
Cool - I may be in touch - I'm in the middle of a move - from Florida to Montana - so everything is a blur - but I will need to buy this kit sooner or later - I'll check back for sure - I am going to attempt to to the mirror/camera check to see if I can identify if the pipes were replaced - my car is a leaking mess - but could be something else - like a large rubber connector hose? Has anyone had luck with the checking with the mirror/camera phone? It seems like a good starting point.
#589
I've been down the coolant pipe road as well. Same scenario as most on this forum. In addition to the coolant pipes, I've replaced the ignition coils, the cardan shaft, the battery, the liftgate struts and all brakes in my '04 CS. All that not withstanding, I love my car and am in the process of (trying to) upgrade to an '06 CTTS. The one I'm considering has 35k on it; 2 owners. I'm wondering if there is some way to track the service history?? Can I somehow find out if these issues have been addressed yet or will I be rolling the dice and holding my breath. I asked the dealer; I got a 'vague at best' response. "Everything works, runs great, no known issues" blah, blah, blah. Thoughts??
hi, I was wondering the same thing? does anyone know of a way to track the service history? 04 CS - only have had a few weeks - love it, but getting the history on it is spotty - is there a way to track history on it? probably not, but just checking - thanks!.
#590
for anyone looking here for info on the turbo tee's, I don't see it mentioned but uro parts makes the lower/larger tee in aluminum for around $25 with the hoses, so you don't have to buy an oem one for the hoses and custom tee and roll your own. I got mine from rockauto but most part supplies seem to have it available.
#591
I just got an 04 cayenne with a high temp coolant leak (not bad).
I assumed it was the cooling pipes when I bought it… turns out they’ve been done since 2017 based on the date on the plastic tube…
There is a bit of antifreeze in the valley but not a bunch.
Any guesses on the source of the leak? I’m going to see if there is a leak on the connection of the bigger tube.
Porsche coolant pipes but they appear to have a seep.
#592
Plastic tubes?
#593
Fixed…
The leak was the forward hose clamp on the back connection of the larger pipe.
I tightened it up using a 7mm wrench under the upper pipes, put 15psi on it and in 2.5 hours the pressure held like a rock. Perfect pressure test.
#596
Hey question for the group. I have seen most pipe replacement videos / posts and the intake is completely removed (along with fuel and vacuum lines). But I saw a recent video where the intake was removed and set on the left side of the motor with the fuel line still installed. It seemed less invasive then removing the fuel lines. Has anyone else done this?
