Roof Rails or Roof Transport System ??
yakima towers in the tracks. very good. i wouldn't consider anything else roof wise. have had the same towers/rack setup on on 06, and now the GTS. yakima does it right.
Has anyone used Thule or Yakima towers in the Cayenne tracks? Good, bad, indifferent?
FWIW, the photo is of the Thule box I'm considering. You gotta admit that it looks a whole lot better than either of the Porsche boxes; and it will look very nice on top of a Meteor Grey Metallic Transsyberia.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Both Thule and Yakima make them. I'll bet that one or both would do the job.
I have a Thule box and the roof crossbars. You need to do a, uhh...,"field modification" to use it because the bars are too big. Just longer bolts, longer bottom plates, and a few drilled holes.
BTW if you move the front bar back, away from one might call a "natural" position, the added noise is a non-issue. My front bar is 12-14" behind the sunroof. Obviously I move it forward if I am carrying something.
Man of Many Porsches
MetCayenne (05-01-2021)
