Aftermarket Subwoofer Installation
Hi all,
I recently bought a base model '04 Cayenne. Lovely car - but having no luck and hoping someone on here could help me. I've searched this forum in detail, its sister forums, roadfly etc with no luck.
IMO - the standard stereo is acceptable, but my car didn't come with the BOSE stereo nor an aftermarket sub and it sounds pretty flat. I would love my car so much more with the addition of a Sub.
I'd like to install a sub in the boot (it's big enough). From research I've discovered is that there are no RCA outputs, I can get around this using a "Hi output to RCA connector" off the rear of the stereo by tapping into the rear speaker wires. Run a pair of RCA's to the boot, plus a power cable from the battery (think this is under the drivers seat).
Pulled the stereo out today - would like to know if there is a wiring diagram for my stereo. Couldn't find one or the specific model number e.g. CDR 220 - The stereo is only labelled "model no: BE 6654 serial no: 45015943"
The closest wiring diagram I found was this:
http://www.modifiedlife.com/2003-por...ing-schematic/
Thank you for your help
Shah
Shah
