Coils Question
Has anyone had their coils replaced twice...
Mine were done at something like 40K+ miles. Now I have 80K and I'm feeling a slight shutter right after start up (which eventually subsides).
Seems like same symptom when coils were bad initially.
Anyone else have theirs replaced twice?
IIRC, yes, there were instances of this, especially early on with the 'redesigned' coil packs.
IMHO, the new ones are not that much better.
Be sure to check the plugs when you're replacing the coil packs.
I spoke to the dealer. I think they are going to cover the cost of replacing them since the first set (installed under warranty) went bad. I think it helps my case that I'm proposing to do this as part of an 80K service (which is pricey). There are offers galore out there these days for discounts on major services.
Done twice. Both times before symptoms got very bad. Last time was about 6 months ago. Don't remember the version numbers right now, but remember looking them up at the time and the (second) failed set was only one revision old, so they weren't that old and had little mileage.
I think most dealer are waiting for the misfire codes to diagnose/change coils. you may want to put some fuel system cleaner through to rule out fuel etc.
