04CTT coolant tubes
Old Jan 24, 2009 | 01:59 PM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Originally Posted by cayenne-kimo
Are there any special tools required to do this job? Can this be done at home over a long weekend?
Just preparing for the inevitable.
Not a comment on your technical capabilities sir because I have no clue what they are but I would suspect that since this was once a "engine drop required" task I would suspect the skill level required of the DIY'er who attempted this task would have to be well beyond oil changes and brake jobs. Just a guess.
I remember several months back there was a photo posted of the engine showing the tubes, I remember because I made a comment about the starter being between the cylinders and under (?) the tubes. That photo might help someone understand what's involved with this.
Old Jan 24, 2009 | 02:43 PM
INURGRL951's Avatar
INURGRL951
From: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Are the same defective pipes on a 06 turbo S? and has anyone has a stater issue i would think to knock that out while you are in there too.
costas
Old Jan 24, 2009 | 04:46 PM
cayenne-kimo's Avatar
cayenne-kimo
Originally Posted by OCNYPORSCHE
There is a TSB on renntech from 2008 that indicates that the engine no longer needs to be taken out, so cost may be less if you are out of warranty.
I was referring to this comment that the engine no longer needs to be dropped to replace the new tubes. I'm not going to do it if I have to drop the engine. So, is it still doable using the new TSB procedures?
Old Jan 24, 2009 | 06:46 PM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
You missed my point. I understand it's no longer a engine drop task but at one time it was. That would suggest to me it is a rather complex or at least involved procedure, that is what I was trying to convey. I may be completely mistaken though, wouldn't be the first time.
Old Oct 30, 2009 | 12:18 PM
CPais's Avatar
CPais
You guys should get an aftermarket warranty so that this is all covered. I don't understand how you can own this car without a warranty to cover all of this.
Old Oct 30, 2009 | 01:25 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
FORE !
Old Oct 31, 2009 | 07:18 PM
v10rick's Avatar
v10rick
If someone locates an after market warranty program that covers this and cracked ignition coils please post it here.
I have checked with 3. They cover the S but not these faults....just stuff that seldom fails.
