Went to the dragstrip
Old 10-11-2008 | 10:41 PM
the head's Avatar
the head
Default Went to the dragstrip
Best runs were brake torquing it to no less than 2000rpm with 2.0 60' times (slow by most standards) but without enough boost/rpm it would drop into the 2.2 second range. I was running 14.0 with said 2.2s, but once I figured out I needed to really crank on it off the line the best run was a 13.79@100.9mph. I put it into manual so it would start in 1st gear. For whatever reason it wanted to start off in 2nd gear in D. I tried manually shifting it, but the best mph was to just swap it back to auto right after the launch. No wheelspin, but I did take the PSM off line. It was also at the lower setting for ride height. Weight was 5695 with me in it - that's a lot! I'm in Houston and the temp was about 80 degrees. Well, now I know what it can do stock.
Quick Reply: Went to the dragstrip
