Stop Radio Station ID Scroll?
'04 Cayenne S with PCM. On my commute I listen to the local NPR station. I guess the last fund drive was successful and they upgraded their transmitter, because now they are sending out over the airwaves a 3 or 4 line station identifier....and it is continuously scrolling on the display of my PCM and the instrument cluster....and I can't figure out how to stop it....it is a distraction....I even read the manual....
OK, it's not the worst thing in the known universe, but it bugs me.
Any ideas?
Any ideas?
Rocky Mountain High
I think there is an option to disable RDS in the PCM menu somewhere. Try the settings menu while you have the station selected.
I've got that deselected and it doesn't make any difference.
Interesting: when I'm in the parking garage - where the signal is weaker - the scrolling stops.
--Bob
Rocky Mountain High
Yes, RDS and RBDS are the same thing. I'm surprised that it doesn't stop when you deactivate it.
I can't for the life of me get mine to display the individual station info, I have a bunch of those L-1, L-2, L-3's ect. Haven't messed with it in a while though.
Yes, I RTFM!, several times, clear as mud. Where did that Technical Writer come from?
Rocky Mountain High
I've also never seen an explanation of what the "L" designation actually means. The manual refers to alternate/secondary programming, but nothing more.
Thanks Dennis, I'll try that next time I'm in the Pepper. I've read technical manuals for 25+ years and read some poorly written ones. This one leaves (me at least) more confused than when I started.
Rocky Mountain High
Let me know if you figure it out! I've looked at it several times and had the same experience as you.
Have you looked at the description of the air diffuser in on the center of the dashboard? The manual tells you how to turn it on and how to turn it off, but doesn't say what it really does or why you would turn it on or off.
And, do you mean that when the Main button is pushed the display reads L-x?
I haven't seen that before....but then I haven't looked. I was happy with just the call letters of the station being displayed.....which is what I used to have before something changed, and I am assuming (without knowing) that the (NPR) station must have upgraded its signal (strength? stream of data?) somehow.
And boy are you right about the manual.
Rocky Mountain High
Which button are you referring to here?
Say, for example, that you are on radio station 92.3 and you have it programmed to button number 2. If that station does have RBDS and other alternate programming, then the ID on the programmed button could show 92.3, it could show the station ID (that station is called "The Fort" here in Fort Wayne, so I think it says FORT or FRT) or it could show L-1, or L-2, etc. If you select that station by pressing button number 2, and then hold that button down as if you are programming the station, the display for the button will change. The problem I have is that sometimes it changes, sometimes it doesn't. Also - there is not an explanation of what L-1 or L-2 really mean.
Rich.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Rocky Mountain High
Rocky Mountain High
I read through as many of the old archives as I could find... this certainly has been a hot topic in the past.
So if I understand correctly, the "L" designation is for "local" stations, and the 1, 2, etc. is for what? I still can't figure out how to simply toggle it back to the station frequency. Again, it hasn't been a big issue for me, because even when I listen to the radio I generally have the PCM screen on "main", which is set to "auto" in my vehicle. I don't see all the buttons very often.
