what oil are you using?
Old 07-04-2008 | 12:16 PM
aaronliu's Avatar
aaronliu
4th Gear
Default what oil are you using?
just curious what brand, grade oil you use for your Cayenne?
Old 07-04-2008 | 05:05 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Factory fill is Mobil 1 0W-40.
However, there are dozens of alternative oils on the Porsche Approved Oil List in several viscosities.
Old 07-04-2008 | 09:07 PM
Slow Guy's Avatar
Slow Guy
Mater of fact I just changed the oil in the Pepper last night, Elf Excellium 5w40. On Porsche's recommended list, Worldwide designation and more importantly for me at least meets the requirements of the 993 air cooled guru's (see VERY long oil thread in 993 forum).
It also comes in 5L jugs (which is what I buy) from Performance Oil Store and their max shipping charge is $20. I run it in all 4 cars, saves on oil storage issues and is recommended by all mfgrs.
Butt dyno says I gain 5 - 7 hp w/ it too! Just Kidding!!!!
Edit: Just checked the site, looks like the Elf has been re-branded "Total Quartz Energy 9000 5w40 5-Liter" and unfortunately it's on back order right now (and the price went up). Oh well. I'll place my next order, they should have it in before I need to change the 993 (it takes 10 - 11 qts.).
Old 07-05-2008 | 01:56 PM
JGriff's Avatar
JGriff
Amsoil Synthetic European 5w-40
Old 09-11-2010 | 05:33 PM
streettriple's Avatar
streettriple
2nd Gear
Default oil brand
castrol syntec, 5-40w, use it every 20 thousand miles,still very clean when i change it.
Old 09-11-2010 | 06:03 PM
yeldogt's Avatar
yeldogt
M1 0W-40 ...... was told that is the factory fill
I changed it at around 10K for the first time because 20K sounded like a lot. It was so clean I took the next one out a little further -- Still unbelievably clean.
Old 09-11-2010 | 06:35 PM
CDH-CTT's Avatar
CDH-CTT
Mobil 1 0W-40 European syn..... I change it every 8k cuz I do a lot of short trips from work to home (less than 5 miles from home to work)
Old 09-11-2010 | 08:08 PM
Andy E.'s Avatar
Andy E.
The V8 Porschephile
PAG has since changed the oil change frequency from 20K to 15K...I wonder why?
Mobil 1 0W-40 European Formula is the only oil that the GTS sees. The 928 still uses the old mineral stuff, Castrol XLR 20W-50
Old 09-12-2010 | 03:16 AM
Alichtenberg's Avatar
Alichtenberg
I may have low mileage on mine, but when it did eat my oil up the first 800-1000 miles, I have used and will be using Mobil ESP formula M 5w-40, because I was told by the book that 0w-40 is used for low temps. So here in GA, I do not want that, and the other one it recommended was 5w-40, and all I saw was ESP formula M, or either Diesel turbo. So I went with ESP formula, and as for 10w-40, it told me that was used for the "S" model.
Old 09-12-2010 | 05:33 AM
bigbuzuki's Avatar
bigbuzuki
Mobil 0W-40.
Quick Reply: what oil are you using?
