Removing rear rotors
So I have searched the forum and I know I need a 12pt Torx (double triangle). for the rear. I will fully admit, I have no idea what this means. I changed the brakes on my 996 and my old ML500 and they all just required a torx bit. While I know the fronts require a t50, the back one is perplexing me.
Also, on the schematics (below), they mention the torx screw n910 282 01 but also a screw plug N 910 380 01. What is the screw plug?
Oh, and has anyone ever used DBA brakes on a Cayenne? Being as they come from the mother country, I though I would give the 4000 series a crack. You can get slotted or drilled/slotted. Think I will try the slotted. The product might be too new for anyone to have had them installed.
CJ
CJ
AKA...cheese head. You can get these at some of the better auto part stores. I got mine from carquest auto and it is made by Lisle. Not too expensive.
I'm glad to know I can use this tool for other things. I bought a set to do my flywheel.
Thank you
I've also heard "12 point socket" used.
