DME Fault Codes
DME Fault Codes
This may explain the drop-off in performance:
Fault Number: P0021
Description: A Camshaft Position -Timing Over-
Repair Infomation: Advanced or System Performance B2
Fault Number: P0344
Description: Camshaft Position Sensor "A"
Repair Infomation: Circuit Bank 1 or Single Sensor
Repair Infomation: No signal / Communication
Fault Number: P1657
Description: Overrun recirculating air valve
Repair Infomation: output stage
Any chance these three are related? A common circuit/fuse perhaps?
Fault Number: P0021
Fault Number: P0344
Fault Number: P1657
Yes, they are related...
Turns out they're all wired to the same part of the same wiring harness that was eaten (allegedly) by the same rodent. No - really.
