"Check Dipped Beam"
Cows-4-Rent
No! not while towing so calm down everyone.
I have just started getting this message and then the bulb goes dark. It works for a few seconds before quitting. Only on the left side.
Any ideas on where to start?
Just call me Pops
That message has been popping up for me couple of times a week practically since day one. Dealer's never able to find anything wrong, it don't bother me and I've learned to ignore it ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Btw, I've checked the lights and everything seems to be on. What am I supposed to be looking for?
Cows-4-Rent
My headlight does go out. I'm going to try to clean the contacts and see if that does anything. After that, I guess it's off to the dealer.
When you take the assembly out, the contacts might very well look perfect, but "clean" them anyway. The Cayenne is weird like that. It appears that if there is the least little increase in resistance you can have issues with warnings. And of course in many cases the bulb will still be lit.
Rocky Mountain High
I've had a similar issue... almost always the passenger's side bulb, but once the driver's side. I've also had the passenger's side turn signal give me an error message. Mine seems to happen more often when it is below 20 degrees F. I'll get around to cleaning the contacts at some point...
Super Moderator
Needs More Cowbell
Needs More Cowbell
Super Moderator
Needs More Cowbell
Needs More Cowbell
Before everyone goes off looking for a #2 pencil eraser to start 'cleaning' electrical contacts......
2 things at play here:
1. Poor connector design, leading to low spring force between bulb assembly electrical contact and connector contact. This can permit water vapor to impinge, leading to electrolytic corrosion.
2. Ohmic (I2R) heating (due to #1 above) leading to further degredation of the aforementioned contacts.
One/Both of these will lead to (intermittent) problems with the Cayenne's in vehicle bulb diagnostic systems.
The correct fix is to simply replace the connector assemblies, but that is time and $$.
So, the next 'correct' fix is to do TWO things....
A. Clean the contacts
B. 'Reform' the contacts in order to provide a more secure/lower resistance electrical connection.
Unfortunately, over time, it is likely to return.
Or at least that's what I heard somewhere on the internet......
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
page 2...my response...
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
OZRacing
The easiest is a pencil/pen eraser, preferably the fine, hard kind used for pens. Make sure you don't leave residue in there.
I agree with Lewis - if you can take a small pick or blade and tweak contacts so they exert more pressure on the bulb, that is a good thing.
There is a good chance that there is an electrochemical process occurring, only because resistance has changed, but I think going to the dealer and installing new contacts would be total overkill and would not affect the issue long-term.
I'll bet your headlamp connector looks fine.
While you're at it, and if you don't want to deal with repeated troubleshooting, you might want to go ahead and replace the bulb. I had the same issue, repeatedly. Left headlamp would blink momentarily and warning light would come on. Would reliably happen during hard acceleration during a left turn, occasionally on a right turn. After multiple trips to the dealer (they first tried cleaning the contacts, then pulling and reseating the unit, then replacing the switch, then multiple other attempts I can't recall), they finally figured out that it was the bulb. Once replaced, the problem disappeared. Two months later, found out that an acquaintance had virtually the same experience with his '04. I still suspect it was the contacts, but on the chance that it could be the bulb, that could be a cheap alternative to much frustration and trouble.
