mObridge Install Question
I have had my mObridge installed. However, because I have never had the cd changer in my car, and in fact did not even have the MOST cable in the changer area, I needed to have the CDC enabled on my CDR23.
Unfortunately, the Porsche dealer has not been able to enable the CDC because he cannot communicate with the radio using the PIWIS. His thoughts were that the mObridge uint was blocking the connection, or there is another issue with the fiber optics. We tried the bypass switch to no avail.
My radio works fine, and I have no error messages. Additionally, the tech said that he can access all other systems in the car, but cannot access the radio.
Has this happened to anyone? Any thoughts before I remove the mObridge unit and try all over again?
Pepper Bartender
........... Unfortunately, the Porsche dealer has not been able to enable the CDC because he cannot communicate with the radio using the PIWIS. His thoughts were that the mObridge uint was blocking the connection, or there is another issue with the fiber optics. We tried the bypass switch to no avail.......... Any thoughts before I remove the mObridge unit and try all over again?
1-888-7-MOBRIDGE toll free in the U.S. (1-888-766-2743) - your dealer's tech rep. is an idiot.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Funny thing is, the service desk rep told me the tech is the best they have for these issues. Didn't make sense to me that everything else was working and could be accessed, but they couldn't access the radio.
Anyone recommend a dealer in the Boston area that is up to speed on this issue?
There are bigger issues if you cant access the Headunit, the Mobridge shouldnt block anything to do with the PIWIS. PIWIS communiacates over CAN-BUS, not fiberoptic. Your tech should know this.
Mark
Mark
However, if I read what you are saying correctly, that will not likely fix the issue.
Were there any CDR23s prodcued that were not CDC compatible? My pepper never had a CDC.
Pepper Bartender
Pepper Bartender
There may be a loop problem.. that is why they're saying re-connect the optics as it was and see if you'll still have an issue. If you don't then the connectors are probably not fitting properly to the mObridge unit. However, all that being said, while I did mine myself and I'm no techie.. it may be other issues since you're not PCM equipped. MM2? Larry?
I dont believe you are using the MOST ring for anything in your Cayenne. It would be used for amp & CDC, but you said you didnt have a most connector in the rear compartment so i would assume your Cayenne doesnt use it. Sorry for the vaugness of my answer but I havent done any aftermarket work on a Cayenne, lots on sportscars though...
Mark
Mark
Mark
Mark
UPDATE: Dealer enabled my CDC after I removed the mObridge from the MOST loop. That's the good news. Bad News: Went to pick it up and the battery was dead. Good stuff. Still at the dealer getting a charge.
Hopefully, I will have the mObridge up and running this weekend.
