SYSTEM ERROR!
What was the last release of DOS you worked on (and no, I'm not talking MS-DOS or PC-DOS - I'm talking the predecessor to DOS/VSE)? I can still remember the EDS stories in SED School of Ross proclaiming that the largest machine EDS would EVER need was a 360/20!
Oh really, I had that EXACT issue with an aftermarket MOBRIDGE unit recently. The unit was installed and i got the system error... Had to program with the PIWIS the Cd changer into the 2 control modules.
Only partially correct, PAG does not offer the setup but VAG does, haven't used it yet, but wouldn't need to. have seen numerous instances of a fiber line bent in too tight of a radius to work, I don't have the spec in hand but it does require a fairly wide arc to stop it from bouncing the light back.
While you may be correct there are other problems it very well could be.
Mark
Mark
Mark
Mark
Pardon me. I obviously stand corrected, by someone who clearly has much more knowledge of these things than I thought I did.
My sincerest apologies to all those involved.
Thanks for the boost of confidence!!!!
Mark
I'm not sure, since I don't know exactly what you've seen.
BTW, how long have you been working on these cars? I am curious, since you seem to have quite a bit of knowledge regarding MOST, POF and the infotainment system.
You're welcome.
Great sense of humor BTW!!!
Mark
Okay guys...old thread I know but I just got the same error on my '04. Didn't install or change anything at all. Just got in like I always do and got the system error CDC/Amp message.
Any ideas if nothing has been messed with?
According to his little green light, he's online at the time of this post.
He is clearly the MOST expert in this forum, based on the posts above.
I doubt there is anything I could do to help when it comes to MOST infotainment device design for Porsches......I mean to do that, you'd have to be the person who actually designed it and I doubt anyone like that would hang around here.
Old is when you remember programmers' toolkits that contained pliers and screwdrivers so you could rewire logic boards at a moment's notice!
Old is remembering 3330's with REMOVEABLE plattens.
Bonus question - What color is your OLDEST IBM Systems Reference Card? I have a Green Card, a White Card AND a Yellow Card. And if I looked hard enough, I can still find my OS-VS1 Control Block books (all 3 volumes!)
Did I say I was OLD?
Sperry Univac 1219B......just a notch above tubes.....
edit: Should have noticed how old this thread was.
