CS Heat Vents Cold Feet!!
Is it just my CS that has the lower heat vents pointing mid calf?? Unless my feet are on the brake pedal they stay cold for a number of miles since there is no heat directed at them. I thought I was hallucinating then a friend drove it and had the same complaint.
Just wondering if anyone has had this issue and found a way to correct it.
Pepper Bartender
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Pepper Bartender
yeah... what he said.
the reality is that it's just incredibly time consuming (i.e. high $$$) and a pain in the **** to do thus the dealers and PCNA prefer not to do what is necessary.. It was better post actuator warranty work.. but my feet were still cold in the wintertime until the entire compartment warmed up..
my complaints about the rear a/c were met with "all of them have weak std. air in the back" -- i.e. PAG wants you to buy the REAR a/c option. Since I bought off the lot when I got my Tit.S (that sounds so wrong) the rear regular vents easily cool the rear seat complaining teens/college boys in no time.. in the Beta they always complained it was hot until the front a/c finally got to the back (10-15 minutes with wifey saying she's freezing in the meantime). After the cold rear Tit.S experience (that sounds so wrong) no REAR a/c option is needed IMHO in the Cayenne (well, unless they build the stretch version that Larry desperately wanted).
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
I had the same thing happen when I drove a Cayenne S. My right foot stayed cold. It seems like the actual placement of the bottom vent doesn't direct the hot air to your right foot while on the go pedal.
FYI- My 928 keeps my feet toasty warm when it's cold outside.
Pepper Bartender
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Thanks, I will push the dealer on my next visit and see if I can get them to do something about it. I've got nothing to lose at this point since it's still under warranty.
