PIWIS tester vs Durametric
Can anyone explain for me the advantage of Piwis versus this: http://www.durametric.com/buy.aspx
I am posting this on several Rennlist forums (perhaps, incorrectly).
Super Moderator
Needs More Cowbell
Needs More Cowbell
PIWIS has full factory support and access to some functions which are 'private'.
It MAY be a matter of time before Durametric et. al. discover how to access these 'private' areas.....but I'm certain once they do and PCNA finds out, the dogs will be released from the legal department.
PIWIS is also ridiculously expensive, requiring VERY frequent S/W updates.
That having been said, the Durametric tool does allow you to avoid some visits to your dealer for simple items. An excellent tool for the DIY type.
PIWIS can do more than 50 times what the Durametric software can do - and the Durametric software can easily do 20 times what a standard code reader can do.
The Durametric software is very good and so far all the updates have been free.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Depending on what you are trying to do when you say 'reconfigure'......dangerous waters.
With PIWIS, you can, in theory, download a new code image to any module that is on a bus (via internal gateways) in the vehicle.
So, you could reprogram your ECU, reprogram your audio infotainment system, etc.
One caveat to add on to what Itc said.
"So, you could reprogram your ECU, reprogram your audio infotainment system, etc." -- with any existing (Porsche) program. So, no custom programing outside of Porsche's preset limits.
Also, to put the two tools in perspective...
The PIWIS is leased from Porsche for $18,000 for the first year and $11,000 for each year after.
The Durametric Software is $247 for a 3 car package.
I have the Durametric Software and a (used) PST2 that I paid $3600 for. The PST2 is the predecessor to PIWIS and it can not program cars after MY2004 and has limited programming for Cayenne.
Super Moderator
Needs More Cowbell
Needs More Cowbell
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
No idea why you would want to, except perhaps if you wanted the audio system to wakup on activity (say, opening the door), and then have the audio system reproduce the sound of someone sitting on a 'whoopie cushion',....hmmn, sounds like something Larry could definitely have done
Official Wednesday AM Red Bull F1 test driver
I have the Durametric and it is handy for checking subsystems on the vehicle but you can't "change" stuff like the VAG-COM system can do on VW-Audi products. It did come in handy lately when my son bought a '06 Cayman as we could check all the systems for any codes etc.
It's a handy tool to have and as Loren said, the updates are free. They didn't have ability to check the PASM when I got it and when I requested it they sent me an upgrade with it for free. They have pretty quick support response...
Wish it did do more as the VAG-COM is VERY handy with my other vehicles...
Technical Guru
Originally Posted by Raptor
s there anything available short of PIWIC that will reprogram/reconfigure?
