HELP:: Sport's Mode on the Cayenne S
Guys, just got an 04 Cayenne S blk/blk. I love it.
But there is a problem. My dad said if you put the car in SPORT'S MODE , you must use the Tiptronic buttuns to shift or the car will have problems.
I think his wrong. I never heard that before. Plus I hate using the buttuns. What do you guys think??
Official Wednesday AM Red Bull F1 test driver
Not sure what you mean by sport mode- turning off the PSM? If so, it still shifts itself, it just starts out in 1st and shifts at higher shift points. The sport mode with PASM has nothing to do with shifting...
Originally Posted by ///ArmanD
No, the cayyene doesn't come with the sport button. It comes with the shift ****..to put it in sport's mode
having it in "manual" mode won't hurt it. Since you don't like shifting with the buttons, i guess you prefer using the shift ****. That won't hurt it.
Pepper Bartender
IMHO, it is a feature that should be put in all their vehicles.. more people would probably opt for automatic if the automatic/manual transmission in the 911, Boxster and Cayman worked like the Cayenne.. are you listening PAG more $$$
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Originally Posted by MadFox
You're confused.. when you push the lever to the left .. you are simply in manual tiptronic mode for the Cayenne.. this feature works differently than any other Porsche automatic transmission.. in the 911, Boxster, Cayman .. when you go to Manual (pull to the left).. only the tiptronic buttons on the steering wheel work.. HOWEVER on the Cayenne.. when you pull it over to the left (manual) then both the tiptronic on the steering wheel can be used AND you can use the auto trans. selector like a stick shift -- i.e. pushing it forward advances the drivetrain one gear.. pulling it to the rear, shifts the transmission down a gear..
IMHO, it is a feature that should be put in all their vehicles.. more people would probably opt for automatic if the automatic/manual transmission in the 911, Boxster and Cayman worked like the Cayenne.. are you listening PAG more $$$![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Pepper Bartender
So, can I leave the shift **** to the left when I drive normally, or do I have to shift.
Now, you're a new user of the forum... and not to be "harsh"... but I've always wanted to use this icon.. and, I'm a little surprised at the questions.. the best place to get the answer is your vehicle's manual.. in fact, it is pretty good reference book.. not great but pretty good.. READ it, there is a lot of good info.. and finally... uh-hum..................
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
Pepper Bartender
Originally Posted by ltc
Could someone please add some chlorine to the gene pool?
Hugs and Kisses from Beyond the Grave,
Larry
Larry
