Winter tires in warm weather
Folks,
I had recently got the winter tires mounted on my Cayenne. I am planning to take a driving trip to Florida and was wondering if I should drive on the winter tires or get the all season mounted back. Issue is that mounting all season and remounting winter tires after the trip will cost me approx. $ 100.
Will I be damaging the winter tires or cause excessive wear by driving almost 2000 + miles in non winter weather.
Thanks for your help and comments.
Super Moderator
Needs More Cowbell
Needs More Cowbell
In general, yes, but the degree to which the tires will wear depends on the brand and/or UTQ. For example, Blizzaks are phenominal in snow (due to the outer compound used), but after extended dry/highway conditions, that spongy rubber will wear off and you are left with a compromised snow tire.
The $100 will likely be less than the amount of wear done to the 4 tires.
It's not exactly unsafe, but you will have a bit less dry weather handling (re: grip) than you are likely accustomed to (and more sidewall flex depending on what diameter your summer wheel/tires are).
