Disable servotronic?
There is quite an annoying delay with servotronic (speed-sensitive power steering). Basically the power boost always come slightly later than I expected.
Is there any way to disable servotronic? I know on Audis you could just simply pull a fuse to disable servotronic modulation.
Thanks.
Thanks.
Okay, found it. There is a relay under the dash board, near the steering column, relay #412.
The steering power assist is quite consistent now. I think it feels better, esp. under quick deceleration.
