Post your repair / warranty list here
#316
2013 Cayenne Diesel
AdBlue Heater replaced
NOx Sensor / sender unit replaced
Turbo Boost hose cracked - replaced
All under extended warranty from Porsche - read the diesel-gate thread if you wish
#319
2011 958.1 CTT (Meteor Gray) Chassis Failure (Fixed Under Fidelity Warranty).. PCM update.
2011 958.1 CTT (Black) Rear Diff replacement. New Transfer Case. Fuel Gauge Error fixed via replacement of sensors (All one visit..) per CPO warranty....
#323
Yup, my 2016 Cayenne with 19K miles is at the dealer for a new transfer case as I type this. A few other warranty items being repaired as well.
Long time Porsche owner: from 911, Spyder, GT4, Macan...this is the first Porsche I have had issues with. Hope this is not an ominous portent of things to come. This is wifey's car so I drive it infrequently. However, if it turns out to be unreliable it is out of here. She's had successive MDXs since 2003 and I bought her the Porsche, although she was partial to another MDX. Hope I don't have to eat it.
#325
8 years of ownership = about $14,000
2009-01-16 Air Suspension Control Unit - Warranty
2009-01-16 Turbo Blow Off Valve - Warranty
2009-04-14 Ignition Coils, Wiper Arm - Warranty
2009-04-14 Rear Wiper Arm - $137
2009-08-17 40k - $1,107
2009-08-17 Parking Brake Strut - Warranty
2009-08-17 Horn - Warranty
2009-11-07 Battery - $129
2010-04-12 50k - $189
2011-04-12 Ash Tray - $234
2011-05-23 60k $214
2013-04-19 Coolant Pipes, Horn, Brake Pads, Stoptech Brake Rotors, Oil Change, Washer Cap $4,796
2013-12-11 Crank Case Breather Hose $453
2014-06-13 70k, Fuel Pumps / Washer Jet $2,753
2014-08-14 Coolant Tank $850
2015-02-11 Struts $178
2015-03-02 80k, Liftgate Struts (install) - $345
2015-02-12 Battery - $342
2015-09-04 T fitting (coolant system), Transverse Mount - $2,598
2016-06-01 Parking Brake Strut - $20
2011-05-23 60k $214
#326
2006 CS Ti. Purchased with 119,xxx miles, now approx 136,xxx miles. Work done: starter, coolant reservoir, brake pads, coils (actually weren't needed), plugs (real cause of misfire code). Not bad for an 11 year old car.
#327
2011-05-23 60k $214
2011-05-23 60k $214
Of course, if you DIY'ed these items, and I do not see any difficult ones on the list, the costs would be less than a third of the $14k. $850 to do the coolant tank??? 60 minutes of work, $85 for the part, $50 for coolant... I am sure the dealers kids are attending good schools with prices like that!
#328
2017-05-15 Oil Change $230
2017-06-09 Power Steering leak, new clip & test $300
2017-06-09 Oil solenoid, seals, Coolant check, Engine Clean, $1324
2017-06-13 Thermostat & Water pump replacement $1542
#329
06 Cayenne Base 6MT- Transfer Case fluid change report
I have been the happy owner of this 06 Cayenne Base with the rare manual transmission since I saw it at the Washington Auto Show in January 06. It's been a very reliable car, with very few repairs, just regular maintenance, oil changes, etc.
I put new coils in when one failed in 2012, and the dealer (in Northern Virginia) hit me for about $900, as I recall. Also needed a new battery approximately the same time, and the installation was around $100, as I recall.
I just this week completed changing the rear diff fluid (using Mobil 1 75/90), and today changed out the transfer case fluid (using D4 ATF).
I wanted to report that the car has sporadically been giving error messages about the 4 wheel drive system in the mini vehicle info display on start-up, over the last 6-7 months. The error generally disappeared if I toggled the 4 wheel drive selector switch in the console once or twice, so I figured I would wait until I needed a more substantial repair to have it looked at. (I live in Toledo, closest Porsche dealer is Ann Arbor, MI)
The old fluid was black, and thicker than the new D4 stuff, which is bright pink. It defintiely needed a change, after 12 years and 73,000 miles!!
After changing the fluid, I tried toggling the switch, and it immediately lit up with "low range on" and then "low range off" when toggled back. These lights had not been coming on for quite a while, so it appears that simply changing the fluid in the transfer case can cure a lot of 4 wheel drive issues!
I've also been dealing with an unknown/ not yet diagnosed thumping in the rear at 28-36 mph, generally only on hard acceleration. Too early to tell if the T/C fluid change will affect that issue. Love the forum, and thought I would post this to encourage anyone who hasn't changed T/C case fluid to give it a try. Only issue was removing fill plug, that took a bit of banging. But it is very accessible and once you get the plugs free, no problem. I used a suction pump, which makes any fluid change a lot easier and less messy. Regards, Dave
#330
2015 CD 33,000 miles: AdBlue heater failed. CEL, code P203B00. Durametric says reductant level sensor range/performance factory fault code 9623
Warranty replacement of "Repair kit Heater" 958 113 901 01 and a refill of urea.
