Too much wind......
Too much wind......
I've got a problem. When I let my two front windows down while driving my Cayenne I am nearly blown out of the car. It is annoying! Has anyone else experienced this? Does anyone know of a solution?
Thanks!
Thanks!
Originally Posted by henna gaijin
Open a rear window about 4" - should be fine.
Driver window and front passenger windows all the way down, rears cracked...4" is very good, sunroof open or cracked.....twisties on the way home....Led Zepplin...LOUD......yep...decompression mode
Roll up the windows??
Thanks! Henna - Rolling the rear windows down about 4" helps. Not perfect, but much better. Charlie - The BOP!BOP!BOP! is pretty awful with the moonroof open. I had tried that before and it wasn't what I was looking for. Grssy - I can't hear the tunes with all that wind. PDX - Just shut up!
Just call me Pops
Or a little bit of Prodigy's Smack My Bi$ch Up
I found that slight adjustment to the rear windows up and/or down from the 4" starting point can "tune" the wind noise to almost nothing. Also, try just one rear window (passenger side seems best). Must have been designed that way, right?
Moderator !x4
Most cars with good seals suffer from both of the problems described. MB has the exact same issue for example.
Drivers window open, open rear 3/4 inches
Sunroof Open, open both rears 3/4 inches
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by TimC.
Open the rear hatch glass with Zeppllin blasting
