Quick Help
No clue as to where the dipstick is located.
The Service Information Technik manual states:
Capacity:
Refill 9.0 liters of JWS 3309 (ESSO)............. Don't know the USA equivalent fluid
Change: 8.5 liters
Interval 240,000 km (150,000) miles
Don't know what you are doing, but if you've got anywhere near 150k on the clock, I'd be shocked.
Capacity:
Change: 8.5 liters
Thank You so much for answering! Whew.
Well, when I put it in drive, it seems to not want to go until I rev it sometimes. Its really weird. I was thinking that the brake calipers were holding it back. As if the calipers have not released or I have a stuck piston on one corner.
It an intermittent thing. So, I thought I would check the fluid level of the tranny to be sure. But for the life of me, I can not find the dipstick. I took off the covers in the engine bay and nothing. There is a 2"X3" carpet flap on the side of the tranny tunnel in the drivers side footwell but doesnt look promising.
Thanks Alot for the reply on the weight/type. That helps most of all. I think Ill take it in on warranty?
Just a shot here but have you crawled under the car and looked at the tranny and checked it there is a fill port on the side like a manual gear box?
I'm grasping at straws here.
