Cayenne Turbo S in Snow?
Agreed, a dedicated 2nd set of tires is better, specially for a Tahoe resident.
But if you had only one set and they were 20" rims, wouldn't all-weather tires be a good choice?
Super Moderator
Needs More Cowbell
Needs More Cowbell
If you don't have winter rated compounds/tires (again, look for the snowflake), you will be driving on black plastic discs pretending to be tires.
IF you were forced to compromise and only have one set of 20" rims, then switching from summer tires to winter tires would be acceptable.
Thanks ltc.
Allow me to clarify what I said and let me know what you think.
I have only one set of rims (and they are 20") and if I wanted one set of tires only that I can use all year long, aren't M+S tires good enough?
I understand the dry-weather performance compromises but are M+S safe enough for light snow use only? Is a winter tire the only solution for driving in a heavy snowfall on uncleared roads?
Super Moderator
Needs More Cowbell
Needs More Cowbell
1. As mentioned previously, a 20" tire's contact patch is a bit wide for driving in deep (more than a few inches) of snow.
2. Temperature, not snowfall, will be the determining factor in reducing available traction, again based on the tire compound.
There is a very large difference in cold/snow conditions between a M+S and a true (snowflake sidewall) high silica (or equivalent) compound tire.....if you've ever tried it, you'll know what I'm talking about. As long as you're aware of what your limitations are going to be (in cold and in warm/dry conditions) and limited to a single set of wheels, you might be able to manage.
On the plus side, a M+S will likely yield much improved tire life over the std homologated summer high performance tires.
Holy crap. This thread is bad news. I use the Cayenne as my snow car, too. Got a set of Bridgestone Blizzaks on 255/18 AT rims for winter use. Absolutely a mountain goat in the snow with those tires. Figured I just use the 18's from the Cayenne S on the new turbo S but... now I'm hosed.
The fun I make for myself... never ends.
Edit - Good news! I just checked the Bridgestone website. They make a Blizzak truck tire in a 265/50QR20. Perfect.
Crying out loud, now I have to buy a new set of winter rims and tires while trying to get rid of the 18's which have great rubber on them.
Anybody want to buy a set of four Bridgestone LM-22 snow and ice tires on AT rims?
Thanks ltc.
Important to note that M+S are not really GOOD at anything... they are "good enough" at several things. They will still break loose when the rubber is really cold or when the road is sticky slush ( a surface that is by far worse than packed snow ).
On a scale of 1 to 10 with 1 being drag slicks and 10 being chains, my personal experience up here would give studs on snow tires a 9, studless snow tires an 8, and M+S tires a 5, summer performance tires a 2.
Nice sidearm BTW
PM me to discuss further.
I am visiting my folks here in Alaska and saw my first Pepper today: Cayenne Turbo S with black out option on sport technos. My folks live on the hillside in south Anchorage where AWD and good snow tires/studs are a must. I really wonder what that owner is going to do this winter.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Studs are allowed here in Alaska from about September 15th through May 1st. Once that time is up the Troopers are pretty quick to ticket due to the damage to the pavement.
The summer Conti's on their summer rims will sit in the corner all winter.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Bridgestone makes a great tire. My turbo S will be running 20" Bridgestone Blizzaks on a set of 20" sport technos I got off of eBay.
If you live in deep snow and don't do much dry pavement/highway driving during the winter, Blizzaks are the tire of choice.
For all around winter (snow, dry, highway) driving, I've never found a tire better than the Continental ContiWinter Contact TS790's (haven't tried the new 810's). On all my previous cars (as well as cars owned by friends who I recommended the 790's to), they have been excellent.
I will say from expeiance the Blizzacks are great in snow and awful on dry pavement. Simple lane transfers on dry pavement are a handful. Never buy them again for that reason.
I have the Perelli Scorpions on 255/19's (dedicated wheels) very good all around tire. So long as you monitor tire pressure they perform nicely. Wheels can be picked up cheap on Ebay. Why pay the money to switch twice a year. At 14 inches of snow the Perelli's performed perfectly with no loss of taction. The turbo S should not be an issue so long as you drive with your head.
Please note that there are two main types of Blizzacks. LM and WS. WS is very good on ice but terrible on dry roads. LM is often V rated and is a reasonable compromise, especially on a AWD car.
