Prodigy connection and 2006 Cayenne
The work around for the 2003-2005 Cayenne does not work because Porsche has eliminated the secondary brake light switch on the 2006 model. Has anyone found a workable solution for the Prodigy brake signal?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by mjw930
Perhaps the brake signal on the connector is now consistant enough so you don't need a work around?
I don't believe the original issue regarding compatability between the Prodigy and brake lights had anything to do with consistency. It consistently didn't work. Period.
The root cause was an incompatability between the Cayenne's integrated vehicle bulb diagnostic functionality/operation (for those students of Cayenne history, it is the same root cause of the "!" and trailer lighting...LED and/or incandescent) and the Prodigy's implementation of brake circuit continuity/diagnostics leading to a contention issue. IIRC, this was discussed back when JFScheck first installed a Prodigy....a search should yield the original posts/discussions on the topic.
Originally Posted by ltc
WTF does consistent enough mean?
What I meant by "consistent" was in reference to the following comment imbedded within the Prodigy installation tech note.
Note: When installing a Prodigy or Intella-Stop Ultra, connect the red wire (BrakeSignal) at the brake pedal switch (Black/Red) rather than at the brake control plug to avoid erratic display conditions.
It certainly wouldn't hurt to make a connector up that used the imbedded brake signal and see if it now mysteriously works. In the interim I suppose someone is going to have to figure out where else they can tap into the brake signal. It would suck if you had to run it all the way back to the tail light.
Super Moderator
Needs More Cowbell
Needs More Cowbell
You just can't resist attacking people can you.
I assume that there is a brake signal present on the connector......
but due to the reasons you posted it wasn't "consistent" enough to be used reliably..
It is very consistent and works everytime when not using a Prodigy.....there are other brake controllers out there.
It certainly wouldn't hurt to make a connector up that used the imbedded brake signal..
Answer: Installing Trailer Brakes:
QTY: PARTS:
2 000979228
1 1J0972782
1 Brake Controller
Get the first two items from a Volkswagon Dealer; Porsche
does not carry the connectors or wires. You can get
the controller from your local trailer store or online from
ETRAILER.COM.
First, remove under tray panel under dash on driver side.
Find 20 torx in center of panel and remove it.
Drop panel down and look for a 4 prong square connector on left side of dash, hanging off of main harness. Might be wrapped with grey foam.
Install the ends of the wires 0009799228
in the 4 slots in the connector, part number 1J0972782.
CONNECTOR IN CAR: WIRE COLOR:
TERMINAL 1: BROWN
TERMINAL 2: RED Check fuse box right
F19, make sure it has a 30 AMP fuse in it.
TERMINAL 3: BLACK/ RED
TERMINAL 4: BLUE
WIRING TO CONTROLLER:
TERMINAL 1: GROUND
TERMINAL 2: B+ POWER ALL THE TIME
TERMINAL 3: STOP LIGHT
TERMINAL 4: TRAILER BRAKE
and see if it now mysteriously works. .
In the interim I suppose someone is going to have to figure out where else they can tap into the brake signal..
Never mind, why do I even bother....it's like watching a one legged person try and kick themselves in the a@$
As ITC said the problem is with the bulb diagnostic system . The signal must be picked up before it reaches the diagnostic system. This would lead me to think that a virgin signal could be picked up from the brake boster or master cylinder.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by mudman2
Yo Yo Yo
nuf
nuf
Could I please have name brand rather than generic? Not really sure the generic is as good as the name brand
Moderator !x4
Not you lewis, your info is fact, as most of us know. Instead of screaming, people need to check the number of posts already contributed by the writer and search for info prior to dis'sing him/her.
The uninformed are always so pious!
Obviously I missed the point about the Prodigy having it's own diagnostics system that was in conflict with the PAG diagnostics hence the incompatibility. What I read, based on the tech note direct from Prodigy, was "eratic" behaviour. To me that seemed to indicate an inconstant signal. I was mearly suggesting that POSSIBLY the signal was changed and would now work.
Since NO ONE has tried the Prodigy unit on an '06 wired directly to the connector no one REALLY knows what the result would be. Sure, we can make assumptions based on our experience but no one here knows what changed in the PAG system (something obviously did, they eliminated the brake switch).
All he had to say was, "The problem is a compatibility issue with the Prodigy, the brake signal from the connector works fine with standard analog controllers. I have no idea what changed in the Cayenne's system so I don't know how to install a Prodigy unit on an '06". Then again, it's not in Lewis' nature to say, "I don't know".
Super Moderator
Needs More Cowbell
Needs More Cowbell
On a side note, would you like to discuss 'our experience' with PAG?
I'm going to go out on a limb and guess that I have a bit more experience with PAG than the average owner/individual......just a guess.
If asked a question for which I do not know the answer, I keep my mouth shut until I learn the answer.
If I do know the answer, then I will offer the solution to the problem as presented.
I do.
I do. BTW, there must still be a brake switch.....you just have to discover where it moved to.
Not true.
I'm sorry if the question was asked and answered before but there's one thing you need to learn about internet forums. Information that isn't moved into an FAQ or a sticky thread will always be asked as time passes and new people enter the forums. To insult people that ask questions you feel have been answered too many times is uncalled for.
I tried the Prodigy on my '06 - no luck. BTW, it is more than an "erratic display." The controller will actually pump the trailer brakes while you are trying to accelerate (I could have lived with it if it was just the display).
The brake switch wire you're looking for is now on the other side of the firewall. A tech at my dealer gave me a wiring diagram and verbal instructions on how to tap into the wire, but I neither have the mechanincal inclination or the desire to pull the car apart. I broke down and bought a Draw-Tite Activator II. It works, but I really would have liked to be able to use the Prodigy.
Also, there are other Tekonsha controllers out there, but they will most likely have the same issue.
