Dual Battery question
Cows-4-Rent
For those of you with the dual battery is it located under the subwoofer cover? Have you pulled the rear cover? Full size?
I am thinking of using it to power some trailer functions but the subwoofer cover is not easily removed making me think that it either is not located there or it is designed so that we don't access it for my intended purposes.
Thanks.
Thanks.
The 2nd battery is under the subwoofer (it's not just a cover it's a contained and connected unit) and appears to be full size.
It's not hard to remove the sub with the right tools. As I recall the trick to get at the two nuts that threaded over studs on the back "edge" is to use a deep well socket and extension.
I think you also have to shift the whole sub forward after it's unbolted to pull it out and get at the connection plug.
