674 MPH Cayenne S (Turbo still faster @ 690 MPH)
Pepper Bartender
I couldn't resist putting this in a new thread. The 200MPH thread got me thinking when WINGLESS made the "dump it out of a plane" speed comment... with a drag co-efficient of .39 we can calculate the actual rate at what our beloved Cayenne would actually "fly" into the earth.
Terminal velocity: An object which is falling through the atmosphere is subjected to two external forces. One force is the gravitational force, expressed as the weight of the object. The other force is the air resistance, or drag of the object. The motion of any object can be described by Newton's second law of motion, force F equals mass m times acceleration a: F = m * a which can be solved for the acceleration of the object in terms of the net external force and the mass of the object: a = F / m. Weight and drag are forces which are vector quantities. The net external force F is then equal to the difference of the weight W and the drag D: F = W - D. The acceleration of a falling object then becomes: a = (W - D) / m . The magnitude of the drag is given by the drag equation. Drag D depends on a drag coefficient Cd, the atmospheric density r, the square of the air velocity V, and some reference area A of the object: D = Cd * r * V ^2 * A / 2
Drag increases with the square of the speed. So as an object falls, we quickly reach conditions where the drag becomes equal to the weight, if the weight is small. When drag is equal to weight, there is no net external force on the object and the vertical acceleration goes to zero. With no acceleration, the object falls at a constant velocity as described by Newton's first law of motion. The constant vertical velocity is called the terminal velocity. Using algebra, we can determine the value of the terminal velocity. At terminal velocity: D = W
Cd * r * V ^2 * A / 2 = W
Solving for the vertical velocity V, we obtain the equation
V = sqrt ( (2 * W) / (Cd * r * A)
Thus, let's assume NO ONE is inside the vehicle and the only "luggage" is ltc's former straight jacket and/or his TCU! The calculation for a S would be if we shoved it out of a cargo plane at 35,000 feet:
V= sqrt ((2*4949 lbs.)/(.39 * air density (fm table) * Area (front view ~ 75.9" x 66.9") A= 35.2 sq.ft.
THUS -- Actual Maximum speed of a Cayenne S is 674.1 MPH! or 988.7 ft/sec.
A Turbo is still slightly faster than a S!! 690.5 MPH or 1012.7 ft/sec
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Do you think we could drop one on PCNA headquarters if a navigation update doesn't happen? A group buy perhaps of a CTT from ebay http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT. You will have to recalculate the weight though to account for a cabin filled with feces, dense fecal matter at that.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
BUT DON"T DO IT!!! The weight of the Cayenne hitting the earth would end all life as we know it and bring us into an "Atomic Winter" while causing the extinction of the "Purpasorus Rex" we all love...
analyst
Correct me ifin I'm wrong, but doesn't this mean that the MY 03 - 04 vehicles have a distinct advantage and would now be coveted over the later model years, because the oft maligned cowboy belt buckles increase the mass of this svelte machine to bolster this impressive top end?
Pepper Bartender
I say end global warming and take out Hammond Drive! Fecal matter (say 500 pounds) and cowboy belt buckles (5 lbs.) in a Turbo pushes the speed to:
752.7 mph or 1104.3 ft/sec!! That's one big pile of **** in Atlanta!
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by Kooser
Do you think we could drop one on PCNA headquarters if a navigation update doesn't happen? A group buy perhaps of a CTT from ebay http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT. You will have to recalculate the weight though to account for a cabin filled with feces, dense fecal matter at that. ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
You should also take into account the reduction in drag caused the rear window microswitch deploying/opening the rear glass hatch during the descent phase of the mission...............
Super Moderator
Needs More Cowbell
Needs More Cowbell
For MadFox............
Sir Bedevere: There are ways of telling whether it is a Cayenne.
Peasant 1: Are there? Oh well, tell us.
Sir Bedevere: Tell me. What do you do with Cayennes?
Peasant 1: Burn them.
Sir Bedevere: And what do you burn, apart from Cayennes?
Peasant 1: More Cayennes.
Peasant 2: Wood.
Sir Bedevere: Good. Now, why do Cayennes burn?
Peasant 3: ...because they're made of... wood?
Sir Bedevere: Good. So how do you tell whether the Cayenne is made of wood?
Peasant 1: Build a bridge out of it.
Sir Bedevere: But can you not also build bridges out of stone?
Peasant 1: Oh yeah.
Sir Bedevere: Does wood sink in water?
Peasant 1: No, no, it floats!... It floats! Throw the Cayenne into the pond!
Sir Bedevere: No, no. What else floats in water?
Peasant 1: Bread.
Peasant 2: Apples.
Peasant 3: Very small rocks.
Peasant 1: Cider.
Peasant 2: Gravy.
Peasant 3: Cherries.
Peasant 1: Mud.
Peasant 2: Churches.
Peasant 3: Lead! Lead!
King Arthur: A Duck.
Sir Bedevere: ...Exactly. So, logically...
Peasant 1: If the vehicle weighed the same as a duck... it's made of wood.
Sir Bedevere: And therefore...
Peasant 2: ...A Cayenne!
The logic, much like Professor MadFox's calculus, is undeniable.
Peasant 2: Wood.
Peasant 1: Oh yeah.
Peasant 1: Bread.
Peasant 2: Apples.
Peasant 1: Cider.
Peasant 2: Gravy.
Peasant 1: Mud.
Pepper Bartender
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Pepper Bartender
Super Moderator
Needs More Cowbell
Needs More Cowbell
If you have a specific target in mind (and Hammond Drive is as good as any other), I know a guy (no names please) who used to design inertial nav systems components a while back.
I'm sure he could come up with something to use PCNA's own NAVTEQ discs along with a cannibalized PCM2 (CD based) system and GPS parts from the Cayenne itself to turnt he Cayenne into a 'smart' projectile.
Could probably also use the rear hatch, moonroof and self ejecting trim and badges as steering fins.
Would be kind of poetic justice........
Pepper Bartender
Could probably also use the rear hatch, moonroof and self ejecting trim and badges as steering fins. Would be kind of poetic justice........
He then lands on the 500 pounds of excrement pre-loaded in the Cayenne.
Someone asks --- Was he African or European??
Another replys ---- I don't know that?!?!!
Madfox responds --- No not African or European..... he was HAWAIIAN ------- is that 5-O theme music I hear?
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Man of Many Porsches
I happen to know of an 04 Cayenne S with 63,792 miles that is currently 'available' for such a mission..........
is it certified?
analyst
Dropping a Cayenne on someone is not something I can condone, any more than I condone dropping houses on wicked witches, of the East.
To quote the Riddler, in Batman and Robin: "If you drop a Cayenne on them, how are they gonna learn anything?" or something like that...
On a related note: the guided block-o-concrete bomb is way cool.
