Own a piece of Cayenne history.....
Super Moderator
Needs More Cowbell
Needs More Cowbell
For Free "!"
If you have been considering towing with your Cayenne, here's your chance to get the 4 pin connector/harness assembly (VAG ....what you think its a Porsche part??.....) P/N 1J0 972 782 from "The Cayenne Formerly Owned by ltc".
That's right, one of the most (in)famous Cayennes in storied PAG history....
The original PAG towing test subject Cayenne....subject of countless experiments and repair attempts.
This 4 pin connector assembly comes GUARANTEED NOT to cause 'total electrical lighting failure and system shutdown'......why?.....because the 7 pin connector connected to the factory tow control unit was involved in that feature.
In all seriousness (if I can be for a very brief moment), this is the 4 pin plug for under the dash, near the parking brake, for your electric brake controller.....it's been discussed in this forum many times. Parts cost was ~ $12 or so.
analyst
Originally Posted by ltc
For Free "!"
I'm in the midst of trying to figure out the whole trailer/Cayenne thing, it's a bit of baptism by fire. Hopefully not literally!
The service dept. was no help at all. They wouldn't touch the install of the controller but they did install the 7 pin connector next to the hitch. (Porsche part) now I guess I need another adapter to turn it into a 4 pin connector.
After reading your post it would appear I do not have all of the wires to complete the install. (I'm hearing the voice of Ed Mc Mahon saying
"You are correct sir!")
Do I need this connector?
Thanks,
John
analyst
The connector is the proper way to add the brake controller. Another option is to use the male Faston tabs, as shown in this topic.
The connector is better.
For Free "!"
This part may possess luck and be used again in any discussions with a reluctant PCNA.
Lewis don't forget to enclose the instructions, rub clockwise 3X and spit downwind once. There that should do it. BTW attach subject to visiting rights.
