Air Suspension Fault
analyst
My vehicle had an air suspension problem. The symptoms were that the yellow air spring faulty, workshop indication would display on the instrument cluster. Also, the vehicle would display that the system was charging when selecting a higher or lower level. The vehicle would also change levels very, very slowly.
The dealer diagnosed the problem. The vehicle had error code 1772, which is pressure sensor signal wire (low pressure in earth talk).
They found that the compressor was bad and replacement corrected the problem.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Originally Posted by skl
What would that cost out of warranty??? Several here would probably love to know...
analyst
The work order does not list the total time units, minutes, for this warranty repair, but the compressor part number is: 955.358.901.01.
