System Error: Amplifier. CD CHanger not avaliable
Pepper Bartender
Originally Posted by mudman2
Also more reliable, 2 potential paths rather than one.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Super Moderator
Needs More Cowbell
Needs More Cowbell
Unfortunately, there really isn't a CTRL-ALT-DEL for a MOST headunit, as all MOST devices have PERMANENT connections to the battery (B+), so in order to do a reboot, it's similar to a laptop....you have to remove/disconnect the battery......then wait about 15-30 seconds for the internal hold up capacitors (don't ask) in the device to discharge. No, I'm not kidding.
FYI While in the shop yesterday the tech performed W555 Software Update DCW555660001.
They also removed the rear spoiler, cleaned the eyelet S and ground plates. It made a huge difference in what i can only describe as the worst FM reception I have ever heard. My 968 without the antenna whip had better reception.
Lewis, At one time I read on renntech that disconnecting the battery will cause you to have to reprogram a lot of on-board modules with a PST-2. Since that time I have been reluctant to do anything that involves disconnecting the battery. Can anyone confirm or deny this?
Also, if you want to power down the head unit why not pull fuses 9-12 on the left fuse box? Is there some other power going into the head unit?
Super Moderator
Needs More Cowbell
Needs More Cowbell
Early versions of some modules had "issues" with disconnecting B+ (depending on what communication/module internal function was underway). The likely symptom would be corrupted memory/configuration errors. Most have been worked out (re: beaten into submission) by now.
The rear comfort module is an example....8-9 updates/revisions since introduction.....hey, why did I lose my "fill in the blank" option....my personal favorite.
However, the MOST DSP amplifier does NOT suffer from this problem! On the flip side, it had problems that I don't want to relive, thank you.
Slight correction to my earlier statement. Fuses 9-12 in the left fuse box are for various entertainment system components, not just the head unit. It seems easier to remove fuses than to disconnect the battery so that's the way I'd go. Pull the fuses to power the thing down, wait 30 seconds, re-install the fuses, then see if the components re-register themselves on the MOST bus.
(That's the Porsche version of CTL-ALT-DEL.)
