Ride comfort on 22"s
Originally Posted by trozenhorse
hi there....how do you find the continental cross contact tires?
Thanks!
Originally Posted by johnsamonas
The Conti Cross-Contact is not a bad tyre.A few vibrations,though.Next time I change I will probably
go for a Pirelli Scorpion.
fwiw: i've had very good luck w/ the scorpions. great tyre imho
hey there...i have 20's kahn with eibach springs....i like the tightness....but it is tough with the roads here in montreal...happy i did not go with the 22's...if you are some where with bad roads stick to 20's....i guess it also depeneds if you will lower it.....cayenne needs some lowering for sure....i wish i ordered the air suspension for it...let me know how you make out....cheers!
got my ties @ touchette as well....just cannot figure out where the slight vibration is coming from......tires are balanced perfectly....they were a little over inflated....set them all to 38 now and it is much better...not as hard....hey fellow montrealer what do you set your tire pressure @???? what tires you running? TR
I have the slight vibration as well... around 112 KPH, tires are balanced perfectly (I watched the guy balance them)
I'm running 38 also, on Pirelli Scorpion Zero's
