Cayenne replacment pedals
Best aftermarket Cayenne replacment pedals I have seen. Just ordered a set...
http://www.ultimatepedals.com/catalo...?cPath=135_141
I got the anti-slip frosted look. Frosted matches the aluminum trim in the Cay, fyi
Sorry pic of gas pedal unavailable. No affiliation.
![](http://www.ultimatepedals.com/catalog/images//porsche/cayenne(2003-present)/brake.jpg)
![](http://www.ultimatepedals.com/catalog/images//porsche/cayenne(2003-present)/footrest_flanged.jpg)
The V8 Porschephile
Resurrecting an old thread. Here are my new aluminum sport pedals I just installed yesterday.
The quality build of these units is very good however, installation is moderate to difficult. This is definitely not an engineered product from the hardware side of things. Although the fasteners are chrome-plated, the holes do not line up with the steel and composite pedal structure making much study necessary before drilling the holes in strategic areas.
Nevertheless, they surely beat the ugly molded rubber stock units.
Andy,
Got the same ones on mine off ebay. Mine came with the parking brake as well and agree that they take a bit to get put onm correctly but you cant beat them for the money
I put these on my Cayman S and they are attached with screws - you drill the holes - nyloc nuts on the back side. As noted, you have to decide which holes to use and where to drill - took some time but they were solid once installed.
Note that you can get rubber inserts for this style in addition to the 'grip' surface. I never installed my rubber inserts.
I like the Porsche logo on Andy's - what's the source for these?
The V8 Porschephile
Contrary to other pedal designs which use individual rubber grommet-like inserts that are installed via the front, this model uses a 2mm thick rubber backing pad with molded oval inserts that fits from the back-side. This design is infinitely precise using CNC and/or CAD design/mfg techniques.
Since the aluminum pedal cover is not 100% contoured to the steel pedal structure, the rubber insert backing allows for making a good overall footprint contact. It also provides a higher level of security and better grip when driving with wet shoes.
These units were sourced from Ebay for about $85 USD. BTW, in case some of you were wondering, they are NOT made in Germany.
