Vibration
After many trouble free miles on my CTT it has developed the dreaded vibration I have been hearing so much about. I called today to make a service appointment and they said it has been a problem.
What if any solutions can I expect from my dealer?
I have discovered that after driving many miles in snow, that there is a build up of gravel, etc. on the inside of the rim that needs to be scrubbed/washed off. Looking at your address, I suspect this is not the cause.
Had this with my 19" rims but after 4,000 miles and a third balance things have been great for the last 8,000 miles....
Don't know if it was a combination of the tires having some flat spots or just never in balance...
Hope this helps....
Hope this helps....
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I had a similar experience. My 04 CT was great and suddenly developed the vibration. Dealer said it was tire balancing. After trying this twice, they said that two of them were defective and replaced them under warrenty. Zero vibration since.
Alex
Alex
is this "dreaded" vibration what I am feeling when I drive between 65-80 and the steering wheel shakes? My dealer tells me that "the porsche has a lot of road feel" and this is normal! Is he full of #$% or do I have to live with this?
Bruce
Bruce
Try checking alignment or wheel weights. This is not right.
I can't quite yet on/in this type of "open" forum, Dealers/PNA do monitor the boards. I will keep you all posted as certain matters materialize over the next few weeks.
Super Moderator
Needs More Cowbell
Needs More Cowbell
And assuming they do, what do they do with the information they gather from their monitoring activity? Are they like Santa Claus, making a list of who's been naughty and who's been nice?
Somehow I doubt a room full of PCNA personnel trying to put names to avatars.
Bruce
Bruce
Originally Posted by Truble10
Just a missing wheel weight. Back to normal!
ltc,
Q1. In trying to find information regarding a prior problem, both my Service Advisor and Service Manager had seen copy of the Threads posted (with my comments), which did not represent them/situation in a favorable light. The problem worked its way out and the comments/feelings were adjusted accordingly.
Q2 & Q3. I think your right, that they do not sit around and monitor the board or are trying to names to the avatars.
Regarding your Santa Claus satire, it was taken with a grain of salt. As I recall, things go better with sugar. You will need your Service Manager on your side if you are going to bat with PCNA. Trust Me, it helps.
