Vibration
Regarding your Santa Claus satire, it was taken with a grain of salt. As I recall, things go better with sugar. You will need your Service Manager on your side if you are going to bat with PCNA. Trust Me, it helps.
If you are 'going to bat' with PCNA, there are more effective means in dealing with the serious issues.
My suggestions as to what kind of bat to bring to the game, if you really want to play:
File suit in court, issue subpoenas asking them to testify regarding their knowledge of the problem within PAG and PCNA; that will normally get things rolling.
At this particular point in time, having multiple P-Cars, a sense of compassion for the dealer/service (they are just the messenger), recording all their service work with 10+ marks to JD Power, and just plain keeping the "aluminum bat" hidden in the car has got things rolling plenty.
Your comments are spot on. I would like to think that it is not lost them that they are dealing with a 40 year old with a lot of car purchasing time left, a Rennlist, PCA and ex.POC member who has compassion for the marque. Time will tell.
I had original Bridgestone Touranzas that lasted 22K (but were bald and dangerous by then) that had the shimmy/vibrations issues. Dealer and I discussed trying Continental SptContact 4 x 4's .. they only lasted 16K and were worse vibration/shimmy than the Bridgestones. READ and HEED the posts here and on roadfly about ROAD FORCE. I am using NON N spec'd. Porsche tires in the 18" wheels with the dealer's consent (they mounted etc.). The new set with 2K miles on them now have NO SHIMMY/Vibration and are Michelin Diamaris (which are N rated in 19" and 20" - don't know why 18" isn't). Each tire had LESS than 10 on Road force numbers.. (one even was a ZERO) lowest ones are on front.. I LOVE THESE TIRES.. after 38K and almost 20 months of owning a Cayenne.. Tire Heaven!
--- I had forgotten that all the Road Force numbers (which is a measurement from the manufacturer -- essentially a quality control issue) were actually under 10. I will buy Michelins again. Just had dealer rotate them at 5K.. no uneven wear, no need to align, just re-balanced and rotated.. STILL no vibration-shimmy. Hope this helps..
My personal opinion is that Porsche has a design tolerance so "tight" that high Road Force tires magnify minor issues within the front drivetrain/steering assemblies. In other words if the problem (hypothetically) is that wheel rims are not perfectly round and because of the precision of this vehicle, if you get toward the high end of the road force tolerance you, as the driver, may feel this vibration all the way through to the steering wheel. Porsche won't ever come out and say the rims or the axle or other things are "wrong" because that would be a recall and then they have to fix ALL Cayennes... and not everyone is having the "issue"... instead, if you have high road force tires and you have whatever the issue is.. you feel it.. INSIST that your DEALER do a road force balance (Hunter is what most dealers have/use to do so) to see what each tires' Road Force at manufacturer of the tire are (and you can't do anything about this as it is the tire's manf. balance). Here is an explanation I got from a google search on a Q/A tire forum:
Q: I have a constant problem with my tires being out of balance...... What is a "road force balance?"
A: Tires can be internally non-uniform, so that when they flex under load, they might not rebound in the same way. This causes vibration even though the tires are balanced statically (not moving) and dynamically (rotating). Rims can also exhibit lateral and radial inconsistencies, adding to vibration. Road force balance systems apply about 1,000-1,500 pounds of force against the rotating tire to both measure and compensate for all the inconsistencies. It simulates the tire/wheels reaction under actual driving conditions. If your tires are going out of balance often, its worth the road force balance to prove the problem is the tires themselves.
Hope this helps. MadFox
In the early days, my Cayenne had the usual vibrations described, but after a few tries they "got it" and even with new tires, a few times, I have never had the vibration since.
I seem to recall I had settings of 37 and 24, now they are 19 or lower.
Bruce
I made my service advisor ride with me on the freeway then we drove a loaner. No vibration. They kept swearing mine was tire balancing. I didn't believe them after the first two times didn't solve it. The third time was the charm though. No problems since.
Alex
