Bluetooth Phones and Cayennes
Has anybody here had any experience adapting a bluetooth phone to PCM? I have a Treo 650 and am wondering if I need to order any special PCM options for a Cay TT to make this work. PalmOne sells a cigarette lighter powered gadget for Treo 650s that acts as a speaker phone - is this the way to go?
Any suggestions appreciated!
I'm not aware of a factory option to adapt bluetooth to PCM. I have the Pieker system that was offered by the dealer and while it works fine, I continually get complaints about the sound quality . . . especially from my wife (I have to hear about it everytime I use it). I'm to the point where I actually turn it off to make a call. Now I am thinking of switching to the Sony solution to see if that makes a difference.
Would love to hear any others experiences with aftermarket bluetooth systems.
Eric
Eric
I put the Motorola Blue Tooth Kit into both my Cayenne and 996. In each case the only choice was to use an FM Modulator. I have had better sounding sound kits but the installations are clean and only the control module shows. They are easy to set up to your various Bluetooth phones, I am in the process of setting up the voice commands. Both of my bluetooth kits are installed in the PCM II systems. Good Luck!!
If you buy the factory phone prep kit, you will discover that you have actually purchased the THB Bury System-8 setup. The nice thing about this arrangement is that THB supports many different phone models via plug-in cradles. In fact, they support a Bluetooth adapter AND have a cradle specifically for the Treo. I have this setup installed on my 2004 S and it works quite nicely. I am using a V60 cradle for my wife's phone out of her S430 and I have the Bluetooth adapter to use with my HP Ipqa H6315 Pocket PC Phone. Mind you, I have the CDR-23 radio and NOT PCM-II. However, I believe that Porsche finally fixed the phone prep kit to work with PCM-II vehicles.
Toby
Toby
Toby, Does this mean that I should get the phone kit and then buy the bluetooth cradle adapter as an aftermarket gadget? Or are you saying something else?
Thanks Toby...and Eric...appreciate your comments.
-dave
-dave
My suggestion would be to purchase and install the factory phone prep kit. Since you did not indicate whether you have PCM-II installed or not, that will be the deciding factor.
If you have ordered your TT and are awaiting build, by all means have the phone prep kit installed at the factory. The after-build installation is NOT a pretty picture - lots of stuff removed and re-installed and you will be paying for about 13 hours of labor. Once the prep kit is installed, you can simply buy the appropriate cradle for your specific phone, or buy the Blue Adapter from THB. Be aware that Porsche contracted with THB for their phone kits since it will integrate with the CDR-23 and the MOST ring. Any System 8 cradle will work with this setup. It is a nice, integrated setup and works quite well in my 2004 S.
Toby
Toby
Thanks, will do,...with all the banter going on about Panoramic roof leaks maybe I'll load up on the phone kit instead!!!!!!!
Toby
Toby
Thanks for this info. I have an '05 TT with a phone prep kit that was installed at the factory, but have not purchased a cradle yet. Do you know where I can order the Bluetooth Adapter from? Who is THB? Do they have a website?
Thanks in advance.
Originally Posted by PorscheCayenne04
I have a Parrot kit hooked up in my S and it works great. The advantage of this kit is that it has a called id screen. Works great with my Motorola V3.
thanks
