XM Radio installation
Mudman,
Did you keep the Ipod as well? How did you set up the dual units if you are using both. I have XM in the sunglass holder (xm commander) and it works fine with the wired FM modulator, but I would like to add my Ipod as well. Thanks.
Moderator !x4
Yes I still have and use both. I thought about the accessory that Kenwood make which gives you a second input but in the end just stuck with 2 fm modulators in series on the antenna.
