How easy is it to change the oil in the Cayenne?
Old 11-24-2008, 03:46 PM
  #46
Slow Guy
Slow Guy's Avatar
Originally Posted by charlieXS
that's because the V6 has the superior Volkswagen design engine
lol... v8 has 2 plugs too right?
correct, 2 drain plugs. The 2nd (rear) plug will drain about .25 qt. when engine is stone cold and apx. .5 qt (maybe little less) when engine is fully hot when changing oil.
The reason I know how much it drains when cold is when I picked up my '06 (CPO) Pepper the oil level was over full on the dipstick from the selling dealer, I don't like that. I used the rear plug to drain the overfill. It worked out well but I had to do it twice.
Old 02-04-2009, 05:57 PM
  #47
slider172
Scared to Look
slider172's Avatar
Make sure to get the right 2 plugs though. I opened the power steering drain plug by mistake.
Only a little drained , but I had to top it off and a liter is $20.
The oil drain plugs are pretty much one in front of the other. The Power steering fluid drain is toward the passenger side about 16".
Old 02-08-2009, 11:04 AM
  #48
n3968w
n3968w's Avatar
Default 04 v-8 oil drain plugs
Here are some pics from my oil change
screws for the corner plates
oil filterName:  P1310019.jpg
notch to remove old 0-ringName:  P2010021.jpg
front drain plugName:  P1310018.jpg
rear drain plugName:  P2010023.jpg
Old 04-12-2010, 11:46 AM
  #49
ninjabones
ninjabones's Avatar
Great post... just tackled my first oil change in the pepper S. What a piece of cake compared with my 993. I ended up flushing the brake fluid as well, while the car was up on the lift.
Wallmart had the 10w-40 5-quart jugs for $23. So, my total cost for brake flush and oil change was about $80 (filter, oil, crush washers, brake fluid) and total time committment about 2 hours. If I planned better, I could have done the brake flush while the oil was draining... bet I could do the whole job in 1 hour if I pushed hard next time.
Old 04-12-2010, 12:36 PM
  #50
Vino
Vino's Avatar
Just did my oil as well, but have done it three times before, I tried LubroMoly Synthoil 5w-40, seems pretty happy with it and is on Porsche oil approval list.
Napa now stocks it.
On the second picture above there is a rectangular object that says BEHR on it, that object has some sharp fins on it and I have opened a nice flesh wound so take caution for first timers, it's right next to the oil filter.
Ninjabones, did you use a Motive brake bleeder to do the brakes?
I have one but still hesitant to use on the Cayenne, I'll try it on the Carrera first. On the Cayenne the bleed screws are well exposed through wheel access so seems pretty easy to do.
Old 04-12-2010, 05:29 PM
  #51
ninjabones
ninjabones's Avatar
Napa now stocks it.
Yes, I used the Motiv power bleeder. piece-o-cake. Only problem I had was actually locating the reservoir. I ended up unscrewing every panel in the engine compartment before figuring out that it was right smack dab in front of my face in the left aft corner with it's own very simple pop-off cover.
Old 04-14-2010, 10:20 AM
  #52
Andy E.
The V8 Porschephile
Andy E.'s Avatar
Here's a question that nobody seems to want to discuss; What do you guys do with the old oil?
Old 04-14-2010, 05:57 PM
  #53
k722070
k722070's Avatar
pep boys, checkers, dealer, jiffy lube. they all take used oil here in utah.
Old 04-15-2010, 02:01 PM
  #54
Shawn D
Shawn D's Avatar
Hey n3968w, how do you like that Amsoil? I have been thinking about switching from Mobil 1 0w-40. Looking to get less oil consumption burning about 1qt/1300miles
Old 06-08-2010, 04:12 AM
  #55
z064ddle
z064ddle's Avatar
10w-40? is it ok to run in Texas weather with this thicker weight oil?
Old 06-08-2010, 11:03 AM
  #56
s4for5
s4for5's Avatar
Default Can an oil extractor be used on this engine?
Perhaps every "other" oil change?
Old 06-08-2010, 01:00 PM
  #57
Kermit
Kermit's Avatar
Yepp. I got an oil extractor a while ago, and wanted to test it last time I changed oil (a few weeks ago) on my Cayenne.
It worked great, but it's of course impossible to get ALL the oil out with those. I got what I could with the extractor and then opened the plugs and changed filter as well. I guess I got about a half to one quart of oil extra out from doing that.
It did help though, since there was less spill from opening the plugs och such. I think I'll go with just using the extractor and refill next time, and do a full change with opening plugs and changing filter every other time from now on.
EDIT: By the way, I didn't have a funnel on my latest oilchange. I cut a standard plastic coke bottle in half and used that - turns out it's an exact fit for the cayenne oil refill opening. It just snapped in there and sat very steadily. Recommended if you're out of funnels
Old 09-06-2010, 11:16 PM
  #58
that2bad
4th Gear
that2bad's Avatar
looks like this (on a v6)
So the oil drain plug is the screw next to the D5?
Old 09-28-2010, 12:04 AM
  #59
Munchdog
Munchdog's Avatar
Dumb question, I see filters like:
but see pictures of the solid black traditional oil filter. On the Cayenne (2006 Turbo), do you re-use the existing cannister and replace the inner filter piece?
Old 09-28-2010, 12:27 AM
  #60
Vino
Vino's Avatar
You are correct, re-use the canister and replace the old rubber seal ring with the rubber seal pictured above and don't forget to oil it. There is a torque spec for the canister, you may want to do a search for the torque specs.
Quick Reply: How easy is it to change the oil in the Cayenne?
