No sound from radio
No sound from radio
Driving home last night I received a phone call and turned down my radio. After the call turned the radio back up and no sound. Played with the volume, changed stations, changed from FM to AM, even tried the cd player. No Sound! I turned the radio on and off still no sound. This morning I started up my CS and bam sound is back. Anyone experience this problem and was there a fix for this? Side note when my CS was new my AM radio would not work, they replaced the radio and it has been working fine for over a year, that is until yesterday.
Issue with amplifier software- needs to be replaced. You can reset by turning off the car, letting the MOST ring power down (it's off when the light around radio power button goes out) and restart. Irritating, but know issue. Mine goes in Friday to get replaced.
It happened once to me a couple weeks ago. Started the car up and ERROR appeared on the radio display. Tried everything while driving, but no luck. Once I turned the car off and restarted, it was fine. Hasn't happened since.
