2008 Cayenne (957) - Tire Sealant Warning ??
Yesterday after being away for a couple of weeks, the rear right wheel had low pressure (19 PSI) which I thought might have been a slow leak from a nail or something but then the dashboard lit up with a bunch of messages about Tire Sealant and offering different options of next steps I should take. Does anyone have any explanation as to what that means and what I should do ? I reinflated the tire but not sure if that's enough. The car has just over 150,000 miles and the tires are otherwise in good shape.
Read the owner's manual. You have to tell the computer what you did to address the tire pressure issue. You do this with the standard menu interface.
