What Fluid is This - Green (Maybe Yellow)
#31
A/C stop leak is bad news. You might need to change the entire A/C system to get it working. Every time that stuff absorbs moisture it congeals into thick goop.
#32
Also, I just removed the refrigerant and pulled a vacuum and there is a slow leak (used to hold overnight) so I presume that is from the compressor and why the oil is leaking. If it held vacuum overnight, then I would really be confused. That said, it was still blowing cold air and the AC gage readings were good...but I bet it was just leak enough out such that it would stop working.
#33
Just to close this out (for the most part), I pulled the refrigerant out and cleaned everything up real good. After running it for a while (20-40 miles) there is no sign of a leak. So I am 99% confident this was compressor oil leaking. And myself and someone else incorrectly theorized that the AC would not work if the compressor fluid was leaking...so that was interesting (and also why I keep my mind open about that scenario). I will know 100% after I replace the compressor (I always like to leave a little space for error), but this is the data I collected.
slavie (03-27-2024)
#34
I can't say for sure if my AC was working for a time while the compressor was dripping oil, but if oil is pooled at the compressor seal and there is a slow leak the gas will push some oil out.
Tire Slime works like this.
It makes sense that the seals would be bathed in oil, there might be a void that is designed to maintain a puddle of oil on top of them.
