Sourcing for replacement door actuator
I've completely disassembled, cleaned, lubed my FL door actuator. The microswitches test reliability for continuity. I'm trying to find a non Porsche branded replacement.
What has worked well?
'04 CTT
Thanks!
'04 CTT
Thanks!
I performed this swap several months ago (approx Jan/Feb '24) and functionality has been exceptional. The link is attached along with pictures of my OEM and replacement "911" next to each other. Unless the link has the part incorrectly listed, this is an ideal swap for others out there experiencing a faulty driver door lock as I have for years. Symptoms were: inconsistent locking/unlocking and hard pressing the key fob to perform prior functionality. I previously disassembled and cleaned the entire actuator assembly only to have the same troubles. Micro switches also tested for continuity.
Hope this helps.
Alternative 955 door lock
Hope this helps.
Hi guys, how many pins does your front and rear locks have? I'm trying to order replacement ones myself from my CT 2008 and I cannot figure out which ones to order since I have the keyless drive system which apparently is unique to the Turbo...
Posted about this before and still searching so any help is appreciated.
Currently looking at these: https://www.ebay.com/itm/352796964412
