Replacement PCM 2.1 radio not working properly?
A question about replacing the OEM Stereo/Nav unit. My original unit went bad a couple weeks ago, so this weekend I swapped it with a visually identical used radio (PCM 2.1) from another 957.
The seller said it was from a 2010, but I know it's not since it's the 955/957 style that was only used through 2008 models.
The replacement radio works fine, starts up normally and the Radio and CD work fine. But it shows an error message at start up, for amplifier, and navigation. Navigation doesn't work and it doesn't detect the Tooki Bluetooth module that's installed. So no Bluetooth either.
How do I get the unit to see both items, and stop showing errors on startup? I did a hard reboot of the PCM, but that didn't do it.
Should I reset the unit to factory settings?
Needs to have the options set with piwis.
