CS alignment
Old Jun 7, 2004 | 01:38 AM
tahoeblue's Avatar
tahoeblue
Default CS alignment
Now have about 1500 miles on my CS and love it.
For the first 1000 miles the alignment as delivered seemed perfect. But at about that time I noticed a steering wheel tilt to the left and a slight pull of the car to the right. Seemed to come on relatively suddenly. Didn't hit anything or remember anything unusual on the road.
Anyone else with a similar experience?
Old Jun 7, 2004 | 12:30 PM
Torags's Avatar
Torags
Did you check tire pressure? The crown direction of some roads will do that - does it do it on all roads/lanes? When you feel it , you might like to try the slow lane of the same road portion. (We will not record the fact a Pepper was seen in the slow lane)... ;-)
Old Jun 7, 2004 | 04:39 PM
tahoeblue's Avatar
tahoeblue
Yes, did check tire pressure. Also does same on areas of road that seem flat, without noticeable crown.
Old Jun 7, 2004 | 04:58 PM
Torags's Avatar
Torags
There is a TSB for initial alignment posted by Muddman2. I don't the # now, I'll look for it.
If recollection serves: After 125 miles when the suspension settles in, the trucks should have alignment checked.
Bring it to dealer, it may be misalignment that would require PCNA to replace tires later...
Good luck...
Old Jun 8, 2004 | 02:58 AM
tahoeblue's Avatar
tahoeblue
Thanks. Let me know if you find # of TSB.
Old Jun 8, 2004 | 06:39 AM
wingless's Avatar
wingless
analyst
The Porsche Technical information document number is 4495, Front Axle Alignment Specifications.
Old Jun 8, 2004 | 06:00 PM
rockitman's Avatar
rockitman
Can a misalignment cause mild wheel shake felt through the steering wheel bewteen 65-75 mph??? My S has 17,000 miles and the shake is becoming more prevalent, even though I noticed this since the begining, but it occured in a much smaller range of mph...Thanks
Old Jun 8, 2004 | 11:45 PM
Torags's Avatar
Torags
Yes. Sometimes the tire wear laterally from the misalignment, giving additional chatter. The tie rod ends are also taking a beating.
Wingless gave you the number, you might like to take it to dealer.
Good luck..
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
