Cayenne Headlight Coating
One question about the headlights.
there is some kind of coating on the headlights. This is a of foil? Some kind of clear paint ? Projection? It’s starting to fail on the drivers side headlight. please see the picture. Difficult to notice on the pictures. Any possibility to renew or I need to get a new assembly? thank you https://cimg2.ibsrv.net/gimg/rennlis...67ed81034.jpeg https://cimg3.ibsrv.net/gimg/rennlis...21b0b97b0.jpeg |
Sand it off to 5000
Spray with https://www.spraymax.com/de/produkte...r/2k-klarlack/ |
Originally Posted by phatz
(Post 19071693)
Sand it off to 5000
Spray with https://www.spraymax.com/de/produkte...r/2k-klarlack/ thank you. I have read about this method and saw some videos. This coating will disappear after sanding this plastic I understand |
Use the Sylvania Headlight Restoration Kit and then after working on the sealant and letting it cure, have them wrapped with clear PPF
Originally Posted by Petza914
(Post 19072305)
thank you ! Do you believe wrapping is possible on a headlight? I thought possible only on plain surfaces . |
Originally Posted by ekstroemtj
(Post 19072398)
My 997 and 928 headlights are also wrapped. |
Looks like someone had the headlights clear coated for additional protection in the past. It works, as clear coat offers UV protection, but correct clear coat compatible with polycarbonate lens must be used. Otherwise, you end up with peeling clear coat...
You'll need to sand down the whole head light to get rid of this. A lot of careful sanding. Then, you'll need to treat this as any old headlight that has lost it's factory applied UV protection: either clear coat it again, apply other UV protectant (those usually last a few months to a year and have to be re-applied), and/or add "clear bra" film (several companies sell those precut). Good luck! |
(Post 19072477)
When I bought new headlights for my Cayenne Turbo S, I had them wrapped to protect them from road debris and so the UV coating wouldn't break down.
My 997 and 928 headlights are also wrapped. thank you |
Originally Posted by slavie
(Post 19072666)
XPEL has a pre-cut headlight & foglight film kit: https://www.xpel.com/Headlamp-and-Fo...-PLUS-XUPL_516
Originally Posted by Malibu955
(Post 19073076)
