PCM2.1 connector type
Does anyone happen to know the make/type of the multi pin connectors on the rear of the PCM2.1 unit? I’m specifically looking to replace plug “A” which is the 8 pin power connector.
The socket on the PCM or the plug on the car wiring?
I doubt you'll find the socket on the PCM unless you buy a junk PCM and salvage it. The plug on the car wiring is a standard DIN plug available most anywhere including Amazon.
Thanks for your reply - I think it might be an ISO plug and socket so I’ve ordered a couple to check them out.
