P1539 - Oil Pump Control code
Old Apr 8, 2023 | 06:05 PM
mbardeen's Avatar
mbardeen
Default P1539 - Oil Pump Control code
Took my Cayenne on an extended trip yesterday, with codes cleared prior. Part of the trip was about an hour of low speed crawl up a mountain trail, and then back down the same trail. I kept getting "Oil pressure sensor" errors that would disappear after a couple seconds on the way up, and nothing on the way down, so I attributed it to gravity pulling the oil away from the sensor.
Today I pulled the codes and found "P1539 - Oil pump control". Anyone experienced this before? A cursory search of the net has yielded suggestions of the camshaft actuator/solenoid, but that doesn't seem right. Nothing about it here either, from what I could find. Would it be related to the Oil pressure sensor light I was getting?
It also had a P2181, but that's a thermostat problem and already on my list of things to fix.
Old Feb 9, 2024 | 07:20 PM
Galan's Avatar
Galan
I have the same two codes on my 08 957. Did you get this resolved?
Old Apr 25, 2024 | 06:56 PM
Aqeel22's Avatar
Aqeel22
Default P1539
hello What is the error after this code p1539 appears?
what did you do ?
thanks
Originally Posted by mbardeen
Took my Cayenne on an extended trip yesterday, with codes clea prior. Part of the trip was about an hour of low speed crawl up a mountain trail, and then back down the same trail. I kept getting "Oil pressure sensor" errors that would disappear after a couple seconds on the way up, and nothing on the way down, so I attributed it to gravity pulling the oil away from the sensor.
Old Apr 30, 2024 | 11:23 PM
greever's Avatar
greever
Following
