2005 Cayenne base servo solenoid help
3rd Gear
First ever post. I was wondering if anyone has a part number for the servo solenoid. I replaced my rack and the solenoid broke causing the PSM to malfunction when coming up to speed on the on-ramp of highway. Also there is a lot of play in the steering wheel u-joint. Has anyone just swapped the u-joint at the bottom of steering column or did you have to replace the entire column. Any help would be much appreciated! Thank you!
Respectfully,
Steve
Respectfully,
Steve
